跳转到主内容
Acer Iconia B1-720 Battery Replacement
你所需要的
  1. Acer Iconia B1-720 Battery Replacement, Rear Case: 步骤 1 中的图像 1,3 Acer Iconia B1-720 Battery Replacement, Rear Case: 步骤 1 中的图像 2,3 Acer Iconia B1-720 Battery Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Battery Replacement: 步骤 2 中的图像 1,3 Acer Iconia B1-720 Battery Replacement: 步骤 2 中的图像 2,3 Acer Iconia B1-720 Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Battery Replacement: 步骤 3 中的图像 1,2 Acer Iconia B1-720 Battery Replacement: 步骤 3 中的图像 2,2
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Battery Replacement, Battery: 步骤 4 中的图像 1,2 Acer Iconia B1-720 Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Peel back the plastic tape covering the battery connector.
  5. Acer Iconia B1-720 Battery Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool to lift the battery off of the back panel. The adhesive used is strong so apply force during removal.
  6. Acer Iconia B1-720 Battery Replacement: 步骤 6 中的图像 1,3 Acer Iconia B1-720 Battery Replacement: 步骤 6 中的图像 2,3 Acer Iconia B1-720 Battery Replacement: 步骤 6 中的图像 3,3
    • Lift the battery off of the panel gently. This will disconnect the battery connector from the motherboard.
结论
5等其他人完成本指南。
Kervis Boston
于03/18/15注册
479 声望
创作了3篇指南
团队
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G1
2 名成员
创作了5篇指南
2条评论
Why the battery has a 4 pin connector? I tried to buy another generic battery but it got only 2 cables, don't know how to replace :(
Tadeu - 回复
I just wanted to throw a red flag out there…I broke my connector off the motherboard trying to reinstall the four-pin connection…can anyone advise?
John Merritt - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,881
