跳转到主内容
Acer Iconia B1-710 Tablet Camera Replacement
你所需要的
  1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: 步骤 1 中的图像 1,3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: 步骤 1 中的图像 2,3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Tablet Camera Replacement: 步骤 2 中的图像 1,3 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 2 中的图像 2,3 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 2 中的图像 3,3
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Tablet Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Tablet Camera Replacement, Camera: 步骤 4 中的图像 1,2 Acer Iconia B1-710 Tablet Camera Replacement, Camera: 步骤 4 中的图像 2,2
    • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
    • Keep the removed screws in a safe place so they can be used later.
  5. Acer Iconia B1-710 Tablet Camera Replacement: 步骤 5 中的图像 1,2 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 5 中的图像 2,2
    • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Acer Iconia B1-710 Tablet Camera Replacement: 步骤 6 中的图像 1,2 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 6 中的图像 2,2
    • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Acer Iconia B1-710 Tablet Camera Replacement: 步骤 7 中的图像 1,3 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 7 中的图像 2,3 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 7 中的图像 3,3
    • Unplug the white wire, shown above, circled in red.
    • Unplug the black wire, shown above, circled in orange.
  8. Acer Iconia B1-710 Tablet Camera Replacement: 步骤 8 中的图像 1,1
    • Gently, remove the motherboard by carefully lifting it.
  9. Acer Iconia B1-710 Tablet Camera Replacement: 步骤 9 中的图像 1,3 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 9 中的图像 2,3 Acer Iconia B1-710 Tablet Camera Replacement: 步骤 9 中的图像 3,3
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
结论
To reassemble your device, follow the above instructions in reverse order.
另外一个人完成了本指南。
Ryan Weber
于03/26/17注册
358 声望
创作了3篇指南
团队
IUPUI, Team S3-G5, Baechle Spring 2017 IUPUI, Team S3-G5, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S3G5
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 352
