简介
The removal of the Motherboard is one of the initial steps in completely taking apart this tablet and is a moderately difficult process.
你所需要的
Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
Two 2.0 mm screws (with the bigger head)
Four 2.5 mm screws (with the smaller head)
The next step is to pull out the ribbon cables connected to the motherboard.
Each ribbon cable has a sticker covering it; peel it off with tweezers.
Use tweezers to pull out the ribbon cable.
另外一个人完成了本指南。
