当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Before taking apart your tablet, make sure the device is powered off.
Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
During this process, the volume button and/or power button may fall out.
Using the plastic opening tool and spudger, carefully pry up the battery from the case.
You should hear the adhesive ripping as you do this.
Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
