跳转到主内容
Acer Iconia A110 Battery Replacement
你所需要的
  1. Acer Iconia A110 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Acer Iconia A110 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. Acer Iconia A110 Battery Replacement: 步骤 2 中的图像 1,3 Acer Iconia A110 Battery Replacement: 步骤 2 中的图像 2,3 Acer Iconia A110 Battery Replacement: 步骤 2 中的图像 3,3
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  3. Acer Iconia A110 Battery Replacement: 步骤 3 中的图像 1,3 Acer Iconia A110 Battery Replacement: 步骤 3 中的图像 2,3 Acer Iconia A110 Battery Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
结论
3等其他人完成本指南。
Andrea
于04/14/14注册
757 声望
创作了5篇指南
团队
Cal Poly, Team 3-42, Maness Spring 2014 Cal Poly, Team 3-42, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G42
4 名成员
创作了5篇指南
一条评论
Where can you purchase the battery for acer iconia tab a110?
redd4167 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 11,234
