跳转到主内容
Acer Iconia A100 Speakers Replacement
你所需要的
  1. Acer Iconia A100 Speakers Replacement, Battery: 步骤 1 中的图像 1,1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Speakers Replacement: 步骤 2 中的图像 1,1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Speakers Replacement: 步骤 3 中的图像 1,1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Speakers Replacement: 步骤 4 中的图像 1,1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Speakers Replacement: 步骤 5 中的图像 1,2 Acer Iconia A100 Speakers Replacement: 步骤 5 中的图像 2,2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
  6. Acer Iconia A100 Speakers Replacement, Speakers: 步骤 6 中的图像 1,3 Acer Iconia A100 Speakers Replacement, Speakers: 步骤 6 中的图像 2,3 Acer Iconia A100 Speakers Replacement, Speakers: 步骤 6 中的图像 3,3
    • Locate the speakers module, which consists of 2 square black speakers connected by wires.
    • Locate the white and blue Home Key FFC ribbon cable between the speakers.
    • Use the tip of a spudger or opening tool to lift up and flip the small hinge on the connector. Then gently pull the FFC ribbon cable out its connector socket.
    • While a metal spudger tool is shown here and may be used, it is best to use a plastic spudger or opening tool when possible. It is easier to damage cables when using metal tools, so be extra cautious when using a metal spudger like the one shown here!
  7. Acer Iconia A100 Speakers Replacement: 步骤 7 中的图像 1,2 Acer Iconia A100 Speakers Replacement: 步骤 7 中的图像 2,2
    • Locate the speaker cable. Use your fingers to pinch each side of the black head of the speaker cable, and gently pull it out of its socket.
    • The metal spudger shown in the photo is used only to identify the speaker cable, not remove it.
    • If you're unable to get a good grip on the black connector head itself, gently pull from the wires near the connector head's base.
    • Be sure to pull on the wires near the base and evenly on the full width of the wires so no individual wire is over-strained, which may cause damage!
  8. Acer Iconia A100 Speakers Replacement: 步骤 8 中的图像 1,2 Acer Iconia A100 Speakers Replacement: 步骤 8 中的图像 2,2
    • Unscrew the 4mm Phillips screws securing the speakers module to the device using a Phillips #00 screwdriver.
    • There are two 4mm screws in total (one screw securing each speaker).
  9. Acer Iconia A100 Speakers Replacement: 步骤 9 中的图像 1,2 Acer Iconia A100 Speakers Replacement: 步骤 9 中的图像 2,2
    • Now both speakers should be free. Use the edge of a spudger tool to lift each speaker off the device, or use your hands to simultaneously lift each square black speaker off of the device.
    • If intact, the two speakers should be connected by wires, forming a one-piece speakers module.
结论
另外一个人完成了本指南。
Omar Acosta
于03/03/15注册
526 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 354
