跳转到主内容
Acer Iconia A100 Battery Replacement
你所需要的
  1. Acer Iconia A100 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Start at any side of the tablet.
    • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
    • Work your way around the tablet.
    • There are four side pieces in total.
  2. Acer Iconia A100 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
  3. Acer Iconia A100 Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully separate the back piece from the device using a plastic opening tool.
    • Remember to open along the entire perimeter of the tablet.
  4. Acer Iconia A100 Battery Replacement: 步骤 4 中的图像 1,1
    • Turn the tablet over so that the battery is facing upwards.
    • Remove the four 4mm screws located around the battery.
  5. Acer Iconia A100 Battery Replacement: 步骤 5 中的图像 1,2 Acer Iconia A100 Battery Replacement: 步骤 5 中的图像 2,2
    • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
    • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
    • Be sure to not have any water around the device while removing the battery.
    • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
结论
2等其他人完成本指南。
Omar Acosta
于03/03/15注册
526 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,863
