简介
If the 3G on your Acer Iconia Tab A100 is failing, you may have a defective 3G Antenna. This guide shows you how to remove / replace the 3G Antenna.
你所需要的
Start at any side of the tablet.
Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
Work your way around the tablet.
Locate the light sensor connector.
Use the tip of a spudger or your fingernail to lift up and flip the small retaining flap on the connector. The light sensor ribbon cable should now be free, so simply pull it out.
Use a Phillips #00 screwdriver to unscrew the single 3.0mm Phillips screw next to the light sensor connector.
Use the flat end of a spudger to pry the gold connector of the antenna cable straight up from the unit.
With the 3G Antenna cable disconnected from the device, lift the 3G Antenna module out and remove it from the device.
