跳转到主内容
Acer Iconia A1-830 Battery Replacement
你所需要的
  1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: 步骤 1 中的图像 1,2 Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: 步骤 1 中的图像 2,2
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Battery Replacement: 步骤 2 中的图像 1,2 Acer Iconia A1-830 Battery Replacement: 步骤 2 中的图像 2,2
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Acer Iconia A1-830 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Battery Replacement: 步骤 5 中的图像 1,2 Acer Iconia A1-830 Battery Replacement: 步骤 5 中的图像 2,2
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
结论
5等其他人完成本指南。
Matt Champagne
于10/20/15注册
458 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G6
3 名成员
创作了5篇指南
2条评论
Is it okay if the battery bends a slight bit when prying it off?
Doof - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 9,086
