简介
Replacing the battery solves charging issues caused by a corrupt or dead battery. Tablets typically use lithium ion type batteries, which are dangerous if punctured, so be careful when handling the battery itself. Use this guide if you wish to replace the battery of your Acer Iconia A1-830.
你所需要的
Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
Shut down your Acer Iconia A1-830.
Remove any cables or exterior covers from your tablet.
Place it on your work space, with the screen facing up.
Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
5等其他人完成本指南。
2条评论
thnks is goood
