简介
Replace the screen of an Acer Iconia A1-810.
你所需要的
Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
15等其他人完成本指南。
一条评论
Before starting to remove the screen, remove the strip of black tape stuck over the screen ribbon cable (right hand end in the last picture) carefully lift the connector lock on the old screen connector and remove the ribbon cable completely.
Fit this ribbon cable to the new display before fitting the screen and the feed it through the slot provided as you install.
