跳转到主内容
Acer Extensa 5220 Thermal Paste Replacement
你所需要的
  1. Acer Extensa 5220 Thermal Paste Replacement, Reaching the CPU: 步骤 1 中的图像 1,2 Acer Extensa 5220 Thermal Paste Replacement, Reaching the CPU: 步骤 1 中的图像 2,2
    • First of all, remove the screws holding the this panel. Open it.
    • It is recommended to disconnect the battery as well.
    • Unscrew the screws holding the CPU heatsink and disconnect the fan.
  2. Acer Extensa 5220 Thermal Paste Replacement, Cleaning the fan: 步骤 2 中的图像 1,3 Acer Extensa 5220 Thermal Paste Replacement, Cleaning the fan: 步骤 2 中的图像 2,3 Acer Extensa 5220 Thermal Paste Replacement, Cleaning the fan: 步骤 2 中的图像 3,3
    • Remove the screw holding the fan to the case and gently remove it.
    • Open the fan (there are a few small screws holding it together) and use a soft brush or compressed air to clean all the dust.
    • After you are done cleaning, reassemble the fan.
  3. Acer Extensa 5220 Thermal Paste Replacement, Changing the thermal paste: 步骤 3 中的图像 1,1
    • Clean the old thermal paste from the cooler, CPU and GPU. It is best to use isopropyl alcohol and cotton buds or paper towel, but be careful not to go too hard on the chips.
    • Once you removed the old thermal paste its time to apply new one. Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order to ensure even pressure. Dont forget to plug in the fan cable.
  4. Acer Extensa 5220 Thermal Paste Replacement, Other upgrades: 步骤 4 中的图像 1,1
    • Once you opened the back cover, it is a good idea to upgrade the RAM, the HDD/SSD or the network adapter if you want.
结论
Simeon Brankov
于11/08/20注册
6,045 声望
创作了49篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 382
