跳转到主内容
Acer E5-571-54FL TrackPad Replacement
你所需要的
  1. Acer E5-571-54FL TrackPad Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL TrackPad Replacement: 步骤 2 中的图像 1,2 Acer E5-571-54FL TrackPad Replacement: 步骤 2 中的图像 2,2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL TrackPad Replacement: 步骤 3 中的图像 1,2 Acer E5-571-54FL TrackPad Replacement: 步骤 3 中的图像 2,2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL TrackPad Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL TrackPad Replacement: 步骤 5 中的图像 1,1
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL TrackPad Replacement: 步骤 6 中的图像 1,1
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL TrackPad Replacement: 步骤 7 中的图像 1,1
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL TrackPad Replacement: 步骤 8 中的图像 1,3 Acer E5-571-54FL TrackPad Replacement: 步骤 8 中的图像 2,3 Acer E5-571-54FL TrackPad Replacement: 步骤 8 中的图像 3,3
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL TrackPad Replacement: 步骤 9 中的图像 1,1
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL TrackPad Replacement: 步骤 10 中的图像 1,3 Acer E5-571-54FL TrackPad Replacement: 步骤 10 中的图像 2,3 Acer E5-571-54FL TrackPad Replacement: 步骤 10 中的图像 3,3
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL TrackPad Replacement: 步骤 11 中的图像 1,3 Acer E5-571-54FL TrackPad Replacement: 步骤 11 中的图像 2,3 Acer E5-571-54FL TrackPad Replacement: 步骤 11 中的图像 3,3
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL TrackPad Replacement: 步骤 12 中的图像 1,3 Acer E5-571-54FL TrackPad Replacement: 步骤 12 中的图像 2,3 Acer E5-571-54FL TrackPad Replacement: 步骤 12 中的图像 3,3
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL TrackPad Replacement: 步骤 13 中的图像 1,3 Acer E5-571-54FL TrackPad Replacement: 步骤 13 中的图像 2,3 Acer E5-571-54FL TrackPad Replacement: 步骤 13 中的图像 3,3
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL TrackPad Replacement, TrackPad: 步骤 14 中的图像 1,1
    • Remove the screw at the bottom of the track pad using the Phillips #0 screwdriver.
  15. Acer E5-571-54FL TrackPad Replacement: 步骤 15 中的图像 1,2 Acer E5-571-54FL TrackPad Replacement: 步骤 15 中的图像 2,2
    • Gently remove the copper adhesive strips attached to the track pad.
    • Remove the two screws using the Phillips #0 screwdriver.
  16. Acer E5-571-54FL TrackPad Replacement: 步骤 16 中的图像 1,2 Acer E5-571-54FL TrackPad Replacement: 步骤 16 中的图像 2,2
    • Pop the track pad out of of the keyboard casing and remove it from the device.
结论
Jennifer Hancock
于09/19/19注册
325 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 12
总计 430
