跳转到主内容
Acer E5-571-54FL Motherboard Replacement
你所需要的
  1. Acer E5-571-54FL Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Motherboard Replacement: 步骤 2 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 2 中的图像 2,2
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Motherboard Replacement: 步骤 3 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 3 中的图像 2,2
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Motherboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL Motherboard Replacement: 步骤 5 中的图像 1,1
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL Motherboard Replacement: 步骤 6 中的图像 1,1
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL Motherboard Replacement: 步骤 7 中的图像 1,1
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL Motherboard Replacement: 步骤 8 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement: 步骤 8 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement: 步骤 8 中的图像 3,3
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL Motherboard Replacement: 步骤 9 中的图像 1,1
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL Motherboard Replacement: 步骤 10 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement: 步骤 10 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement: 步骤 10 中的图像 3,3
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL Motherboard Replacement: 步骤 11 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement: 步骤 11 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement: 步骤 11 中的图像 3,3
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL Motherboard Replacement: 步骤 12 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement: 步骤 12 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement: 步骤 12 中的图像 3,3
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL Motherboard Replacement: 步骤 13 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement: 步骤 13 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement: 步骤 13 中的图像 3,3
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL Motherboard Replacement, Wi-Fi Card: 步骤 14 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement, Wi-Fi Card: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Locate the Wi-Fi card. It is just below the fan and has a white coaxial cable and a black coaxial cable attached to it.
    • Grab the section of the white coaxial cable behind the brass connection using ESD safe blunt nose metal tweezers.
    • Carefully lift the white and black coaxial cables up and forward to disconnect the them from the Wi-Fi card.
  15. Acer E5-571-54FL Motherboard Replacement: 步骤 15 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the 3 mm screw from the upper left corner of the Wi-Fi card.
    • The edge of WiFi card will lift up as the screw is removed.
  16. Acer E5-571-54FL Motherboard Replacement: 步骤 16 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 16 中的图像 2,2
    • Grab the upper left corner of the Wi-Fi card with your fingers.
    • Gently pull the Wi-Fi card away from the socket.
  17. Acer E5-571-54FL Motherboard Replacement, Cooling Fan: 步骤 17 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement, Cooling Fan: 步骤 17 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement, Cooling Fan: 步骤 17 中的图像 3,3
    • Locate the CPU cooling fan in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws that secure the fan to the case.
  18. Acer E5-571-54FL Motherboard Replacement: 步骤 18 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement: 步骤 18 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement: 步骤 18 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Place the tips of the ESD safe pointed tweezers between the plug and the socket of the fan connection.
    • Gently push the tweezers to the left to disconnect the fan plug.
    • Move the fan connector and its wires to free them from the motherboard and the Wi-Fi card.
  19. Acer E5-571-54FL Motherboard Replacement: 步骤 19 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 19 中的图像 2,2
    • Lift the curved end of the fan by about 30 degrees.
    • Use your hand to lift the fan up and to the right until it is clear of the case.
    • If you feel resistance, check if the fan connector and wires are stuck under the motherboard or under the Wi-Fi card. If the connector or wires are stuck, gently free them.
  20. Acer E5-571-54FL Motherboard Replacement, Hard Drive: 步骤 20 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement, Hard Drive: 步骤 20 中的图像 2,2
    • Locate the hard drive and its carriage at the lower right corner of the laptop.
    • Release the USB port ribbon cable by using the plastic opening tool to carefully lift up the black locking tab of the ZIF connector.
    • Move the USB port ribbon cable to the side.
  21. Acer E5-571-54FL Motherboard Replacement: 步骤 21 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 21 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws securing the hard drive carriage in place.
  22. Acer E5-571-54FL Motherboard Replacement: 步骤 22 中的图像 1,1
    • Hold the right side of the laptop in place with your right hand.
    • Put the fingers of your left hand along the top edge of the hard drive carriage.
    • Push the hard drive carriage towards your right hand to disconnect it from the motherboard.
    • This procedure may require more force then other procedures.
  23. Acer E5-571-54FL Motherboard Replacement: 步骤 23 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 23 中的图像 2,2
    • Lift up the hard drive carriage on the edge closest to your body to remove it.
    • If doing the motherboard replacement guide, skip the next step.
  24. Acer E5-571-54FL Motherboard Replacement: 步骤 24 中的图像 1,3 Acer E5-571-54FL Motherboard Replacement: 步骤 24 中的图像 2,3 Acer E5-571-54FL Motherboard Replacement: 步骤 24 中的图像 3,3
    • Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
    • Using a Phillips #0 screwdriver, remove the 3 mm screw to release the side of the hard drive from the carriage.
    • Repeat the previous bullet to remove the second 3 mm Phillips #0 screw.
  25. Acer E5-571-54FL Motherboard Replacement, Motherboard: 步骤 25 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement, Motherboard: 步骤 25 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws.
  26. Acer E5-571-54FL Motherboard Replacement: 步骤 26 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 26 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Place the tips of the ESD safe pointed tweezers between the plug and the socket of the speaker connection.
    • Gently push left to disconnect the speaker plug.
  27. Acer E5-571-54FL Motherboard Replacement: 步骤 27 中的图像 1,2 Acer E5-571-54FL Motherboard Replacement: 步骤 27 中的图像 2,2
    • Place your fingernails on each side of the screen connection plug. Gently push away from your body to disconnect the plug.
  28. Acer E5-571-54FL Motherboard Replacement: 步骤 28 中的图像 1,1
    • Carefully lift up on the right edge of the motherboard near the hard drive connector.
    • With minimal force, pull the motherboard to the right freeing the ports on the left from the case.
    • Put down the right side and allow the motherboard to rest in the case.
    • There is still one connection to be removed which lies underneath the motherboard.
    • Lift the left side of the motherboard up and turn it over so the ports are now facing right.
  29. Acer E5-571-54FL Motherboard Replacement: 步骤 29 中的图像 1,1
    • Grip the edge of the motherboard closest to your body with your non-dominant hand.
    • Grip the power connection wires with your dominant hand and gently pull away from your body to disconnect.
  30. Acer E5-571-54FL Motherboard Replacement: 步骤 30 中的图像 1,1
    • Lift the motherboard out of the case.
结论
3等其他人完成本指南。
Aaron Weissman
于10/23/17注册
1,004 声望
创作了7篇指南
团队
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 UMass Dartmouth, Team S3-G8, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G8
3 名成员
创作了8篇指南
一条评论
Hi is this the DDR4 with Geforce MX Series Vcard variant or the older DDR3?
Paul Ray Supan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,859
