跳转到主内容
Acer Chromebook cb3-532-c47c LED Board Replacement
你所需要的
  1. Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c LED Board Replacement: 步骤 2 中的图像 1,2 Acer Chromebook cb3-532-c47c LED Board Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the battery cable: 步骤 3 中的图像 1,1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: 步骤 4 中的图像 1,2 Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: 步骤 4 中的图像 2,2
    • Flip the retaining latch up with a spudger.
  5. Acer Chromebook cb3-532-c47c LED Board Replacement: 步骤 5 中的图像 1,2 Acer Chromebook cb3-532-c47c LED Board Replacement: 步骤 5 中的图像 2,2
    • Pull the cable straight out away from the front of the computer.
  6. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: 步骤 6 中的图像 1,3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: 步骤 6 中的图像 2,3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: 步骤 6 中的图像 3,3
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
结论
另外一个人完成了本指南。
Jerry Wheeler
于03/21/22注册
75,759 声望
创作了71篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 126
