跳转到主内容
Acer Chromebook cb3-532-c47c Display Assembly Replacement
你所需要的
  1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 步骤 2 中的图像 1,2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the battery cable: 步骤 3 中的图像 1,1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: 步骤 4 中的图像 1,2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: 步骤 4 中的图像 2,2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: 步骤 5 中的图像 1,2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: 步骤 5 中的图像 2,2
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: 步骤 6 中的图像 1,2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: 步骤 6 中的图像 2,2
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 步骤 7 中的图像 1,3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 步骤 7 中的图像 2,3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 步骤 7 中的图像 3,3
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Right Hinge Screws: 步骤 8 中的图像 1,1
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 步骤 9 中的图像 1,2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 步骤 9 中的图像 2,2
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Left Hinge Screws: 步骤 10 中的图像 1,1
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 步骤 11 中的图像 1,2 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 步骤 11 中的图像 2,2
  12. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 步骤 12 中的图像 1,3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 步骤 12 中的图像 2,3 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 步骤 12 中的图像 3,3
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
结论
另外一个人完成了本指南。
Jerry Wheeler
于03/21/22注册
47,914 声望
创作了53篇指南
团队
Oregonians Oregonians 的会员
Community
6 名成员
创作了149篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 263
