跳转到主内容
Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement
你所需要的
  1. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 2 中的图像 1,1
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 4 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 4 中的图像 2,2
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out by pulling upward.
  6. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: 步骤 6 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement, Speakers: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Lift the retaining flaps of the two ZIF connectors into the upright position using the flat end of the spudger.
    • Unplug the tabs from the connectors by gently pulling them out with the tweezers.
  7. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 7 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 7 中的图像 2,2
    • Slide back both sides of the locking mechanism of the touchpad using the narrow end of the spudger.
    • Unplug the trackpad wire by gently pulling it out of the connector with the tweezers.
  8. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 8 中的图像 1,1
    • Unplug the audio connector from the motherboard with the tweezers.
    • Be sure to pull the plug by holding it at the base, not yanking on the wires, as this could damage the device.
  9. Acer Chromebook R11 CB5-132T-C1LK Speakers Replacement: 步骤 9 中的图像 1,1
    • Pop the speakers off of the device by hand.
    • They are held on only by a mild adhesive and should come off easily.
结论
Harrison DeWitt
于04/26/17注册
101 声望
撰写一个指南
团队
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G2
4 名成员
创作了12篇指南
一条评论
Hi, do you know how to replace the microphone on this chromebook?
Álvaro Guzmán Parrochia - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 610
