跳转到主内容
Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement
你所需要的
  1. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 2 中的图像 1,1
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 4 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 4 中的图像 2,2
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out by pulling upward.
  6. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Orient the laptop so the motherboard side is further away from you in a landscape position.
    • Use the flat end of the spudger to lift the the ZIF connector retaining flaps securing the three small ribbon cables.
  7. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull out the locking mechanism of the touchpad ZIF connector with the narrow end of the spudger.
  8. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 8 中的图像 1,3 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 8 中的图像 2,3 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, pull the five ribbon cables near the bottom of the motherboard from their sockets.
    • Using tweezers, pull the single cable near the top left of the motherboard from its socket.
  9. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the screen connector from the motherboard by pulling directly upward on the black tabs.
  10. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the 2.0 mm screw from the Wi-Fi card.
  11. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 11 中的图像 1,1
    • Slide the Wi-Fi card out from the port with tweezers.
  12. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the two 4.5 mm screws and a 2.0 mm screw from the middle of the motherboard.
  13. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 13 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 13 中的图像 2,2
    • Unscrew the two 4.5 mm screws from the top right metal tab connected to the motherboard.
    • Lift the right corner upward to remove the metal tabs from the motherboard
  14. Acer Chromebook R11 CB5-132T-C1LK Motherboard Replacement: 步骤 14 中的图像 1,1
    • Lift the motherboard upward to completely remove it from the base.
结论
9等其他人完成本指南。
团队
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 42
总计 5,301
