跳转到主内容
Acer Chromebook R11 CB5-132T-C1LK Camera Replacement
你所需要的
  1. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: 步骤 1 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Insert the metal spudger into the groove on the edge of the screen.
    • Carefully slide the spudger from one corner to another.
    • When there is room for a finger, remove the screen by gently lifting it out of the computer.
  2. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: 步骤 2 中的图像 1,1
    • Using a heavy duty spudger, lift the camera off the screen base.
    • The camera will be connected to the base with an adhesive.
  3. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: 步骤 3 中的图像 1,1
    • Unplug the camera from its port.
结论
团队
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G2
4 名成员
创作了12篇指南
一条评论
Hi Elizabeh, can you do a tutorial to change the mic on this chromebook?
There was a production batch of this chromebook that had a problem with the mic. So a lot of people could benefit from this.
Cheers!
Álvaro Guzmán Parrochia - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 502
