简介
In case the camera is no longer functioning, this guide explains how to access and remove it from the Chromebook.
你所需要的
Insert the metal spudger into the groove on the edge of the screen.
Carefully slide the spudger from one corner to another.
When there is room for a finger, remove the screen by gently lifting it out of the computer.
即将完成!
结论
一条评论
Hi Elizabeh, can you do a tutorial to change the mic on this chromebook?
There was a production batch of this chromebook that had a problem with the mic. So a lot of people could benefit from this.
Cheers!
