跳转到主内容
Acer Chromebook R11 CB5-132T-C1LK Battery Replacement
你所需要的
  1. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 步骤 2 中的图像 1,1
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 步骤 4 中的图像 1,2 Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 步骤 4 中的图像 2,2
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out by pulling upward.
结论
3等其他人完成本指南。
Alan Shan
于04/26/17注册
382 声望
创作了3篇指南
团队
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 4,646
