跳转到主内容
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
你所需要的
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: 步骤 2 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: 步骤 2 中的图像 2,2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: 步骤 4 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Carefully slide the wireless card out of its socket from the motherboard.
结论
Connie Hernandez
于09/01/21注册
517 声望
创作了4篇指南
团队
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 311
