跳转到主内容
Acer Chromebook R11 C738T-C44Z Speakers Replacement
你所需要的
  1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: 步骤 2 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: 步骤 2 中的图像 2,2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 4 中的图像 1,1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: 步骤 5 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: 步骤 5 中的图像 2,2
    • Gently remove the LED Board Ribbon connected to the mother board.
  6. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 6 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 6 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 6 中的图像 3,3
    • Gently pry up speaker up using a spudger or opening tool to remove it.
    • It has an adhesive, so you might have to use some force.
    • Screwdrivers should not be used as prying tools and could cause damage to delicate components.
    • Repeat the same process for the other speaker.
  7. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 7 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 7 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 7 中的图像 3,3
    • Use the opening tool to unplug the speaker cable from the motherboard.
    • Disconnect the keyboard ribbon cable from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 8 中的图像 1,1
    • Using the opening tool to unlock and disconnect the touchpad cable.
  9. Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 9 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 9 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: 步骤 9 中的图像 3,3
    • Gently lift the speakers up and remove the cable from the system.
结论
另外一个人完成了本指南。
Connie Hernandez
于09/01/21注册
517 声望
创作了4篇指南
团队
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 121
