跳转到主内容
Acer Chromebook R11 C738T-C44Z Motherboard Replacement
你所需要的
  1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: 步骤 2 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: 步骤 2 中的图像 2,2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 4 中的图像 1,1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: 步骤 5 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: 步骤 5 中的图像 2,2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  6. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  7. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 7 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 7 中的图像 2,2
    • Carefully slide the wireless card out of its socket from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Disconnect the LED board ribbon by pulling it out gently.
    • Disconnect the speaker cable.
  9. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 9 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the keyboard ribbon.
    • Slide it out gently to not rip it.
  10. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 10 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 10 中的图像 2,2
    • Disconnect the daughterboard ribbon by flipping up the white tab and pulling it out from the motherboard.
  11. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 11 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 11 中的图像 2,2
    • Disconnect the touchpad ribbon by lifting up the tab and pulling it out.
  12. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 12 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 12 中的图像 2,2
    • Disconnect the sensor cable by pulling it out.
  13. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 13 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 13 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 13 中的图像 3,3
    • Disconnect the LCD cable by pinching it and lifting it off the motherboard.
  14. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 14 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 14 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws that hold the hinge down.
  15. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 15 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 15 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 15 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the motherboard.
  16. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 16 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 16 中的图像 2,2
    • Slide the opening tool underneath the hinge latch to lift it up.
    • This is to free the motherboard.
  17. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 17 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: 步骤 17 中的图像 2,2
    • Grab the motherboard securely to lift and remove it.
结论
另外一个人完成了本指南。
Connie Hernandez
于09/01/21注册
517 声望
创作了4篇指南
团队
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 499
