跳转到主内容
Acer Chromebook R11 C738T-C44Z Battery Replacement
你所需要的
  1. Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: 步骤 2 中的图像 1,2 Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Battery Replacement: 步骤 3 中的图像 1,1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Battery Replacement: 步骤 4 中的图像 1,1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
结论
To reassemble your device, follow step one and two in reverse order.
团队
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 22
总计 473
