跳转到主内容
Acer Chromebook R11 Battery Replacement
你所需要的
  1. Acer Chromebook R11 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Battery Replacement: 步骤 2 中的图像 1,1
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Battery Replacement: 步骤 3 中的图像 1,1
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by pulling upwards.
结论
9等其他人完成本指南。
团队
USF Tampa, Team 1-2, Kass Spring 2017 USF Tampa, Team 1-2, Kass Spring 2017 的会员
USFT-KASS-S17S1G2
4 名成员
创作了6篇指南
一条评论
Hi. Incidentally while you have it apart check for heating of the chip that controls the USB3 port: this is known to be a weak point. As with many low end laptops they can’t run external devices like hard drives properly so may report incorrectly that they need formatting. Fix is to use external power device.
Andre De Guerin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 56
总计 9,632
