跳转到主内容
Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement
你所需要的
  1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: 步骤 1 中的图像 1,2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the laptop over so that the backside is facing up.
    • Use a Phillips #0 screwdriver to remove nine screws along the perimeter of the back case.
    • Use an opening tool to pry the case around the perimeter and gently release the clips attaching the back case to the front.
    • Lift the back case off of the Chromebook.
  2. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: 步骤 2 中的图像 1,2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove two screws on either side of the battery.
  3. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: 步骤 3 中的图像 1,2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: 步骤 3 中的图像 2,2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out to disconnect the battery from the motherboard.
  4. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: 步骤 4 中的图像 1,2 Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the battery from the Chromebook.
结论
另外一个人完成了本指南。
Matthew Supplee
于09/22/22注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 7
总计 152
