跳转到主内容
Acer Chromebook CP5-471-C0EX Trackpad Replacement
你所需要的
  1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: 步骤 1 中的图像 1,2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 2 中的图像 1,3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 2 中的图像 2,3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 2 中的图像 3,3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 3 中的图像 2,2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: 步骤 4 中的图像 1,2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: 步骤 4 中的图像 2,2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 5 中的图像 1,1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: 步骤 6 中的图像 1,3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: 步骤 6 中的图像 2,3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: 步骤 6 中的图像 3,3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  7. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 7 中的图像 1,3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 7 中的图像 2,3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 7 中的图像 3,3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  8. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 8 中的图像 1,2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 8 中的图像 2,2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 9 中的图像 1,2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 步骤 9 中的图像 2,2
    • Carefully remove the trackpad from the device.
结论
另外一个人完成了本指南。
团队
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 的会员
GCC-SAKNEE-S22S1G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 117
