跳转到主内容
Acer Chromebook CP5-471-C0EX Motherboard Replacement
你所需要的
  1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use your hands to lift the battery out of the device.
  3. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: 步骤 3 中的图像 1,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: 步骤 3 中的图像 2,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: 步骤 3 中的图像 3,3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  4. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 4 中的图像 1,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 4 中的图像 2,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 4 中的图像 3,3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  5. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 5 中的图像 1,2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  6. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 6 中的图像 1,2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the trackpad from the device.
  7. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Wi-Fi Card: 步骤 7 中的图像 1,1
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  8. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 8 中的图像 1,2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 9 中的图像 1,1
    • Gently pull the wireless card away from the motherboard to remove it.
  10. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: 步骤 10 中的图像 1,2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: 步骤 10 中的图像 2,2
  11. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 11 中的图像 1,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 11 中的图像 2,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 11 中的图像 3,3
    • Unwind the Wi-Fi card wires from the side of the fan.
    • The wires need to be pulled down and around the first hook, as seen in image two.
    • Pull the black and white cables under the second hook and away from the fan.
  12. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 12 中的图像 1,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 12 中的图像 2,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 12 中的图像 3,3
    • Pull wires so they are out the way.
    • Loosen the six screws from the fan and heat sink.
    • The two screws closest to the fan cannot be removed from the fan, but will still loosen from the case.
  13. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 13 中的图像 1,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 13 中的图像 2,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 13 中的图像 3,3
    • Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
    • Pull the cable out of its socket on the motherboard.
    • Remove the fan from the laptop.
  14. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: 步骤 14 中的图像 1,2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: 步骤 14 中的图像 2,2
    • Push on the sides of the connector to gently disconnect the speaker cable from the motherboard.
  15. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 15 中的图像 1,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 15 中的图像 2,3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 15 中的图像 3,3
    • Use an iFixit opening tool to pry the display cable up from the motherboard.
  16. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 16 中的图像 1,2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 16 中的图像 2,2
    • Remove seven 3 mm screws from the motherboard using a Phillips #1 screwdriver.
  17. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the motherboard from the laptop.
结论
另外一个人完成了本指南。
Naomi Salas
于04/05/22注册
244 声望
创作了2篇指南
团队
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 的会员
GCC-SAKNEE-S22S1G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 306
