你所需要的
Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
Gently slide the black ribbon out from its socket and under the white ribbon.
即将完成!
结论
另外一个人完成了本指南。
