跳转到主内容
Acer Chromebook CB5-571-C5XU Fan Replacement
你所需要的
  1. Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: 步骤 1 中的图像 1,2 Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 2 中的图像 2,2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: 步骤 3 中的图像 1,2 Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, unscrew the screw to the right of the fan.
    • Remember to have a small container to place the screw in, so it does not get lost.
  4. Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 4 中的图像 1,2 Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #0 screwdriver, unscrew the four screws connecting the heatsink to the motherboard.
    • Remember to have a safe place to place the screws, so none of them get lost.
  5. Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 5 中的图像 1,3 Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 5 中的图像 2,3 Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 5 中的图像 3,3
    • Carefully unhook the black and white wires from the circumference of the fan.
    • It might help to use the pointed end of the spudger tool to unhook the wires.
    • Do not tug too hard on the wires, as they can easily disconnect and snap off from the motherboard.
  6. Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 6 中的图像 1,2 Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 6 中的图像 2,2
    • Using the spudger tool, carefully remove the wires connecting the fan to the motherboard.
  7. Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 7 中的图像 1,2 Acer Chromebook CB5-571-C5XU Fan Replacement: 步骤 7 中的图像 2,2
    • Using the flat side of the spudger, firmly pry the fan off of the components, as well as the heatsink from the motherboard.
结论
另外一个人完成了本指南。
Erin Moffatt
于10/17/17注册
282 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 UMass Dartmouth, Team S6-G1, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 279
