跳转到主内容
Acer Chromebook CB5-571-C5XU Battery Replacement
你所需要的
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: 步骤 1 中的图像 1,2 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB5-571-C5XU Battery Replacement: 步骤 2 中的图像 2,2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: 步骤 4 中的图像 1,1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: 步骤 5 中的图像 1,1
    • Gently lift the battery out and remove it from the laptop casing.
结论
To reassemble your device, follow these guidelines in reverse order.
3等其他人完成本指南。
Kenneth Bowers
于04/08/16注册
1,381 声望
创作了7篇指南
团队
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 的会员
UMASSD-VALLIERE-F18S1G1
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 824
