跳转到主内容
Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board Replacement
你所需要的
  1. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 步骤 1 中的图像 1,2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 步骤 1 中的图像 2,2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 2 中的图像 1,1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: 步骤 3 中的图像 1,3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: 步骤 3 中的图像 2,3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: 步骤 3 中的图像 3,3
    • Identify the port that is connected to the speaker.
    • Using tweezers, separate the cable from the port.
  4. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 4 中的图像 1,2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 4 中的图像 2,2
    • Find and remove the blue tape from the circuit board.
  5. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 5 中的图像 1,3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 5 中的图像 2,3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 5 中的图像 3,3
    • Remove the black tape from the port.
  6. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 6 中的图像 1,3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 6 中的图像 2,3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 步骤 6 中的图像 3,3
    • Identify the two Phillips screws.
    • Remove the two screws holding down the board with a J1 Phillips screwdriver.
    • Gently lift the board from the Chromebook.
结论
另外一个人完成了本指南。
2条评论
Any ideas about where to purchase this part? I am almost certain that it is the problem with my sound. Also, I can get to it no problem, but I am struggling finding a replacement part.
littlemas2 - 回复
I have looked on numerous pages on google, both with the part number and with the Chromebook model number and have yet to be able to find a supplier.
littlemas2 -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 654
