跳转到主内容
Acer Chromebook CB5-312T-K 8Z9 Battery Replacement
你所需要的
  1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 步骤 1 中的图像 1,2 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 步骤 1 中的图像 2,2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: 步骤 2 中的图像 1,1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: 步骤 3 中的图像 1,3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: 步骤 3 中的图像 2,3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: 步骤 4 中的图像 1,3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: 步骤 4 中的图像 2,3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: 步骤 4 中的图像 3,3
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,408
