跳转到主内容
Acer Chromebook CB5-132T-C8ZW USB Port Replacement
你所需要的
  1. Acer Chromebook CB5-132T-C8ZW USB Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
  2. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 2 中的图像 2,2
    • Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
    • Do not immediately remove the back from the laptop. The power strip keeps the backing attached to the rest of the laptop. Gently lift backing from the power button side and set next to the body of the laptop.
  3. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 3 中的图像 2,2
    • Remove two 4.6 mm JIS # screws at each end of the battery.
  4. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 4 中的图像 1,3 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 4 中的图像 2,3 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 4 中的图像 3,3
    • Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
    • Remove the battery.
  5. Acer Chromebook CB5-132T-C8ZW USB Port Replacement, USB Port: 步骤 5 中的图像 1,2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement, USB Port: 步骤 5 中的图像 2,2
    • From the back panel, remove one 3.4 mm JIS #1 screw.
  6. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 6 中的图像 1,2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 6 中的图像 2,2
    • Remove the white connector strip using your fingers.
  7. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 7 中的图像 1,2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: 步骤 7 中的图像 2,2
    • Lift the USB port up using a spudger.
    • Remove the USB port with your fingers.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 531
