跳转到主内容
Acer Chromebook CB315-3HT-C3FQ Speaker Replacement
你所需要的
  1. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 步骤 3 中的图像 2,2
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 步骤 4 中的图像 1,2 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 步骤 4 中的图像 2,2
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Unplug the speaker cord from the motherboard's port.
    • Remove the speakers from the laptop.
    • Scan the QR code located in between the left and right speakers. The QR code will take you to different sites that sell the internal speakers that are for the Acer Chromebook 315.
结论
另外一个人完成了本指南。
Kyle
于03/20/24注册
327 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-5, Santin Spring 2024 UMass Dartmouth, Team 1-5, Santin Spring 2024 的会员
UMASSD-SANTIN-S24S1G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 22
