跳转到主内容
Acer Chromebook CB315-3HT-C3FQ Network Card Replacement
你所需要的
  1. Acer Chromebook CB315-3HT-C3FQ Network Card Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Network Card Replacement: 步骤 2 中的图像 1,1
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Network Card Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB315-3HT-C3FQ Network Card Replacement: 步骤 3 中的图像 2,2
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Network Card Replacement: 步骤 4 中的图像 1,2 Acer Chromebook CB315-3HT-C3FQ Network Card Replacement: 步骤 4 中的图像 2,2
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Network Card Replacement, Network Card: 步骤 5 中的图像 1,1
    • Gently unplug the two (white and black) wires from the network card.
  6. Acer Chromebook CB315-3HT-C3FQ Network Card Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the screw blocking the network card.
    • Remove the network card from the laptop.
结论
Ethan Sylvia
于03/20/24注册
351 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-5, Santin Spring 2024 UMass Dartmouth, Team 1-5, Santin Spring 2024 的会员
UMASSD-SANTIN-S24S1G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 6
总计 28
