跳转到主内容
Acer Chromebook CB315-3HT-C3FQ Display Replacement
你所需要的
  1. Acer Chromebook CB315-3HT-C3FQ Display Replacement, Display: 步骤 1 中的图像 1,1
    • Pop off the front panel that holds the Acer Chromebook's LCD screen.
    • If you are struggling to remove the front panel, you can always use a Jimmy to remove the panel.
  2. Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove ten screws that are holding the LCD screen to the top-half of the Acer Chromebook.
  3. Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 3 中的图像 2,2
    • Remove the transparent tape used to hold the LCD connector.
  4. Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 4 中的图像 1,3 Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 4 中的图像 2,3 Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 4 中的图像 3,3
    • Pull out the double-sided tape that is attaching the LCD screen to the frame of the Acer Chromebook by grabbing the tip of the tape (it should be poking out above the LCD screen) and pulling away from the frame.
    • If you're having trouble removing the tip of the double-sided tape, you can use a metal spudger to separate the tip from the frame.
  5. Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 5 中的图像 1,2 Acer Chromebook CB315-3HT-C3FQ Display Replacement: 步骤 5 中的图像 2,2
    • After pulling out the double-sided tape, remove the LCD screen by simply popping it out of the frame.
    • At the bottom of the LCD screen, there will be a QR code that can be scanned on your phone. The QR code will take you to different websites that sell the designated LCD screen for the Acer Chromebook 315.
结论
另外一个人完成了本指南。
Kyle
于03/20/24注册
327 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-5, Santin Spring 2024 UMass Dartmouth, Team 1-5, Santin Spring 2024 的会员
UMASSD-SANTIN-S24S1G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 34
