跳转到主内容
Acer Chromebook CB3-532-C47C Touchpad Replacement
你所需要的
  1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Touchpad Replacement, Remove the battery cable: 步骤 3 中的图像 1,1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: 步骤 4 中的图像 1,2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: 步骤 4 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the laptop.
  6. Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: 步骤 6 中的图像 2,2
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  7. Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 7 中的图像 1,1
    • Pull the ribbon from the motherboard laterally off the touchpad.
  8. Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  9. Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 9 中的图像 1,3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 9 中的图像 2,3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 9 中的图像 3,3
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  10. Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 10 中的图像 1,3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 10 中的图像 2,3 Acer Chromebook CB3-532-C47C Touchpad Replacement: 步骤 10 中的图像 3,3
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
结论
Sadie Brown
于10/25/21注册
967 声望
创作了7篇指南
团队
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 191
