跳转到主内容
Acer Chromebook CB3-532-C47C Speaker Replacement
你所需要的
  1. Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Speaker Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB3-532-C47C Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Speaker Replacement, Remove the battery cable: 步骤 3 中的图像 1,1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: 步骤 4 中的图像 1,2 Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: 步骤 4 中的图像 2,2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  5. Acer Chromebook CB3-532-C47C Speaker Replacement, Speakers: 步骤 5 中的图像 1,1
    • Pry the right speaker up with your hand to remove.
  6. Acer Chromebook CB3-532-C47C Speaker Replacement: 步骤 6 中的图像 1,2 Acer Chromebook CB3-532-C47C Speaker Replacement: 步骤 6 中的图像 2,2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  7. Acer Chromebook CB3-532-C47C Speaker Replacement: 步骤 7 中的图像 1,1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
结论
Sadie Brown
于10/25/21注册
967 声望
创作了7篇指南
团队
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 116
