跳转到主内容
Acer Chromebook CB3-532-C47C Motherboard Replacement
你所需要的
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB3-532-C47C Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: 步骤 3 中的图像 1,1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: 步骤 4 中的图像 1,2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: 步骤 4 中的图像 2,2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: 步骤 5 中的图像 1,3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: 步骤 5 中的图像 2,3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: 步骤 5 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: 步骤 6 中的图像 1,2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: 步骤 6 中的图像 2,2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: 步骤 7 中的图像 1,3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: 步骤 7 中的图像 2,3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: 步骤 7 中的图像 3,3
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: 步骤 8 中的图像 1,3 Acer Chromebook CB3-532-C47C Motherboard Replacement: 步骤 8 中的图像 2,3 Acer Chromebook CB3-532-C47C Motherboard Replacement: 步骤 8 中的图像 3,3
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: 步骤 9 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: 步骤 10 中的图像 1,1
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
结论
另外一个人完成了本指南。
Sadie Brown
于10/25/21注册
967 声望
创作了7篇指南
团队
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G2
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 750
