跳转到主内容
加入维修社区 - 创建账户
Acer Chromebook CB3-431-C5EX Wireless Card Replacement
浏览量: 2170
浏览统计数据:
过去24小时
2
过去 7 天:
19
过去 30 天:
86
总计
2,170
评论: 1
1 comment on steps.
已完成: 3
3 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 2
2 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 5 - 10 分钟
难度: 中等
This repair guide is designed to instruct you on how to replace the wireless adapter in your Chromebook. All you will need for this replacement is a Phillips #0 screwdriver and a plastic spudger. Remember to completely power down your Chromebook before working on it, and handle the internal components of you Chromebook with care as they are fragile.
你所需要的
工具
    1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Bottom Panel: 步骤 1 中的图像 1,1
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Turn device over so the bottom panel is facing you.
      询问修复机器人
      添加评论
    2. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 步骤 2 中的图像 1,1
      • Remove the eight 4mm Phillips #0 screws.
      • Remove the two 6mm Phillips #0 screws.
      添加评论
    3. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 步骤 3 中的图像 2,2
      • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
      • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
      • There are several clips holding the cover in place.
      • Remove the bottom panel and set it aside.
      询问修复机器人
      添加评论
    1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
      • Remove the 4mm Phillips #0 screw securing the wireless adapter to the main circuit board.
      询问修复机器人
      添加评论
    2. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 步骤 5 中的图像 1,1
      • Unplug the Wireless adapter from the main circuit board by giving the adapter light pressure and sliding it out of its port.
      询问修复机器人
      添加评论
    3. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: 步骤 6 中的图像 1,1
      • Detach the two cables from the Adapter by pulling directly up on them, and then remove the adapter.
      • Note that the black cable is already detached in this photo to show what it looks like with the cables removed.
      • Be sure to note the original locations of the black and white cables when installing the new wireless adapter.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G3
5 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 86
总计 2,170
