跳转到主内容
Acer Chromebook CB3-431-C5EX Speaker Replacement
你所需要的
  1. Acer Chromebook CB3-431-C5EX Speaker Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Speaker Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB3-431-C5EX Speaker Replacement: 步骤 3 中的图像 2,2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Speaker Replacement, Internal Speakers: 步骤 4 中的图像 1,1
    • Remove the two 4mm Phillips #0 screws securing the speaker.
  5. Acer Chromebook CB3-431-C5EX Speaker Replacement: 步骤 5 中的图像 1,2 Acer Chromebook CB3-431-C5EX Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the speaker from the computer.
    • Repeat the previous steps to remove the second speaker from the computer.
    • Note that the two speakers are connected by a wire, so you must replace both of them.
  6. Acer Chromebook CB3-431-C5EX Speaker Replacement: 步骤 6 中的图像 1,2 Acer Chromebook CB3-431-C5EX Speaker Replacement: 步骤 6 中的图像 2,2
    • Disconnect the speaker wire from the circuit board by grabbing the plug by its plastic edges and gently pulling it straight out.
结论
另外一个人完成了本指南。
Cayley Ho
于04/18/17注册
545 声望
创作了3篇指南
团队
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G3
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,008
