跳转到主内容
加入维修社区 - 创建账户
Acer Chromebook CB3-431-C5EX Power Port Replacement
浏览量: 1.1万
浏览统计数据:
过去24小时
2
过去 7 天:
27
过去 30 天:
119
总计
11,230
评论: 8
1 comment on steps, 7 guide comments.
Go to guide comments
已完成: 14
14 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 1
1 人收藏(并订阅)了本指南。你会是下一个吗?
所需时间: 没有估计
难度: 中等
This is a guide designed to instruct you on how to replace the power port on your Chromebook. Make sure that your computer is powered off before you begin to work on it. All you need for this replacement is a Phillips #0 screwdriver, a plastic spudger, and tweezers. Remember to be careful when handling the internal components of your computer as they are fragile.
你所需要的
工具
    1. Acer Chromebook CB3-431-C5EX Power Port Replacement, Bottom Panel: 步骤 1 中的图像 1,1
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Turn device over so the bottom panel is facing you.
      询问修复机器人
      添加评论
    2. Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 2 中的图像 1,1
      • Remove the eight 4mm Phillips #0 screws.
      • Remove the two 6mm Phillips #0 screws.
      添加评论
    3. Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 3 中的图像 2,2
      • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
      • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
      • There are several clips holding the cover in place.
      • Remove the bottom panel and set it aside.
      询问修复机器人
      添加评论
    1. Acer Chromebook CB3-431-C5EX Power Port Replacement, Power Port: 步骤 4 中的图像 1,2 Acer Chromebook CB3-431-C5EX Power Port Replacement, Power Port: 步骤 4 中的图像 2,2
      • Remove the four 4mm Phillips #0 screws from the hinge plates on the two corners of the laptop.
      • Remove any manufacturers tape holding in the wires.
      询问修复机器人
      添加评论
    2. Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 5 中的图像 1,2 Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 5 中的图像 2,2
      • Disconnect black and white wires from the wireless adapter by gently pulling up on the metal connectors with your fingernail.
      询问修复机器人
      添加评论
    3. Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 6 中的图像 1,2 Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 6 中的图像 2,2
      • Open hinges to the screen. and then slide base of the computer off of the hinges.
      • It is easiest to do this by holding the hinges in place and opening the entire laptop. Then close the laptop while letting the hinges remain open.
      • This will detach the base of the computer from the screen in order to allow better access to the power port.
      询问修复机器人
      添加评论
    4. Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 7 中的图像 1,2 Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Detach the power port plug from the main circuit board by grabbing it by the sides of the plastic with the tweezers and gently pulling it out.
      询问修复机器人
      添加评论
    5. Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 8 中的图像 1,2 Acer Chromebook CB3-431-C5EX Power Port Replacement: 步骤 8 中的图像 2,2
      • Remove the power port entirely from the computer by pulling up on the plastic portion of the port with a plastic opening tool.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
14等其他人完成本指南。
作者
与
Cayley Ho
于04/18/17注册
548 声望
创作了3篇指南
团队
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G3
5 名成员
创作了60篇指南
7指南评论
I need a link to the replacement part for a new power port!
Tom Adams - 回复 分享
Require a link for a new power port
Kieran Davies - 回复 分享
Do a search for 50.GC2N5.003
Scott Hardin - 回复 分享
The guide is excellent and easy to follow.
However, a word of advice. If you do want to disconnect the wires be warned that their terminals are extremely small and difficult to get back if damaged. It appears to be a soft metal and if you do not line them up exactly the holes on the wireless chip will distort and you will find it impossible to put them back on. I speak from experience and the only solution is to either buy a new wireless adaptor or to solder the wires on.
That itself is fiddly and I have yet to find out if it has worked on mine. (I need to buy a soldering iron). As the wire is an antenna only, I am assured that it should still work even without a connection, provided that you are near the router.
My recommended procedure is not to disconnect the wires but instead to take the small screw out of the adaptor itself and then press down and slide it out. That will free the two halves of the computer without separating the wires.
Ron Seymour - 回复 分享
Thanks for giving my Chromebook a new lease on life! I followed all of the steps except (1) disconnecting the wireless adapter and (2) separating the base from the screen. Those two steps seemed unnecessary, and since I don't repair my own devices regularly, I was worried I might cause more trouble for myself than the convenience was worth. The rest was very helpful and clearly written/highlighted in the photos. Thank you again!
K.E.H. Ellis - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 119
总计 11,230
