跳转到主内容
Acer Chromebook CB3-431-C5EX Display Replacement
你所需要的
  1. Acer Chromebook CB3-431-C5EX Display Replacement, Display: 步骤 1 中的图像 1,1
    • Make sure the work area is clean and free from dirt and debris.
    • Open the lid of the laptop.
    • Place the laptop so the screen is facing upwards and the outside of the laptop is flat against a table.
  2. Acer Chromebook CB3-431-C5EX Display Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB3-431-C5EX Display Replacement: 步骤 2 中的图像 2,2
    • Carefully insert an opening tool under the screen bezel and gently pry it away from the edge of the screen.
    • Slowly slide the opening tool around the bezel on all four sides to separate it from the screen.
    • Be careful to not damage any wires that are under the bezel, or crack the bezel itself.
  3. Acer Chromebook CB3-431-C5EX Display Replacement: 步骤 3 中的图像 1,1
    • Remove the four 2.8 mm screws from the screen using a Phillips #0 screwdriver and place them to the side for use later.
    • Be careful to not touch the tape protecting the display circuit board.
  4. Acer Chromebook CB3-431-C5EX Display Replacement: 步骤 4 中的图像 1,3 Acer Chromebook CB3-431-C5EX Display Replacement: 步骤 4 中的图像 2,3 Acer Chromebook CB3-431-C5EX Display Replacement: 步骤 4 中的图像 3,3
    • Gently lay the screen against the keyboard.
    • Carefully remove the adapter connecting the display to the motherboard.
  5. Acer Chromebook CB3-431-C5EX Display Replacement: 步骤 5 中的图像 1,1
    • Once you have separated the screen from the motherboard, carefully remove the display from the laptop.
结论
To reassemble your device, follow these instructions using a replacement screen, in reverse order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 299
