跳转到主内容
Acer Chromebook CB3-431-C5EX Battery Replacement
你所需要的
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB3-431-C5EX Battery Replacement: 步骤 3 中的图像 2,2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: 步骤 5 中的图像 1,2 Acer Chromebook CB3-431-C5EX Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the entire battery pack out of the laptop.
结论
7等其他人完成本指南。
Elsa Bassett
于04/18/17注册
399 声望
撰写一个指南
团队
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 的会员
CPSU-BANGHART-S17S17G3
5 名成员
创作了10篇指南
2条评论
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - 回复
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 60
总计 8,242
