跳转到主内容
Acer Chromebook CB3-131-C3KD Track pad Replacement
你所需要的
  1. Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: 步骤 1 中的图像 1,2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 2 中的图像 1,3 Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 2 中的图像 2,3 Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 3 中的图像 2,2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 4 中的图像 1,2 Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 5 中的图像 1,2 Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: 步骤 6 中的图像 1,2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: 步骤 6 中的图像 2,2
    • Remove the (3) three 7.0mm screws using the J0 screwdriver head.
  7. Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 7 中的图像 1,2 Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 7 中的图像 2,2
    • Unlock the latches on both ends of the ribbon cable, and pull to detach.
    • The ribbon cable will still be attached to the tape.
  8. Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 8 中的图像 1,1
    • Peel the tape that is on top of the trackpad.
  9. Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 9 中的图像 1,2 Acer Chromebook CB3-131-C3KD Track pad Replacement: 步骤 9 中的图像 2,2
    • Lift the trackpad out of the Chromebook.
结论
另外一个人完成了本指南。
Ashley Oxner
于09/26/17注册
704 声望
创作了3篇指南
团队
USF Tampa, Team S11-G1, Passmore Fall 2017 USF Tampa, Team S11-G1, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 416
