跳转到主内容
Acer Chromebook CB3-131-C3KD Keyboard Key Replacement
你所需要的
  1. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 1,2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 2,2
    • Make sure you turn off the laptop before starting.
    • Place the flat head screw driver under the key, but over the key clip retainer.
  2. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: 步骤 2 中的图像 1,1
    • Push down on one of the bottom corners of the key, so that the opposite diagonal corner rises and gives leeway.
    • Carefully place the flat head screw driver under the raised corner.
    • Carefully pry up from underneath the raised corner to raise the metal clips away from the key base.
  3. Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: 步骤 3 中的图像 1,2 Acer Chromebook CB3-131-C3KD Keyboard Key Replacement: 步骤 3 中的图像 2,2
    • Pry up from the top left and right corners of the retainer subsequently.
    • Remove clip retainer.
结论
Johnathan
于09/26/17注册
216 声望
创作了2篇指南
团队
USF Tampa, Team S11-G1, Passmore Fall 2017 USF Tampa, Team S11-G1, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G1
3 名成员
创作了10篇指南
一条评论
I mean… That’s half of the replacement… so there’s that.
Darren D. MacDonald - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 1,504
