跳转到主内容
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
你所需要的
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: 步骤 1 中的图像 1,1
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: 步骤 2 中的图像 1,2 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: 步骤 2 中的图像 2,2
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
结论
4等其他人完成本指南。
Tony
于01/20/16注册
459 声望
创作了2篇指南
团队
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G5
3 名成员
创作了8篇指南
一条评论
no help i need help putting it on with out that
Simon Kuhn - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 83
总计 7,210
