跳转到主内容
Acer Chromebook C740-C4PE Touchpad Replacement
你所需要的
  1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 步骤 1 中的图像 1,3 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 步骤 1 中的图像 2,3 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 2 中的图像 1,1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 3 中的图像 1,1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 4 中的图像 1,3 Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 4 中的图像 2,3 Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 4 中的图像 3,3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
  5. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: 步骤 5 中的图像 1,2 Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: 步骤 5 中的图像 2,2
    • Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
    • Lift the silver restraint from the device.
  6. Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 6 中的图像 1,1
    • Unscrew the five screws on the touchpad.
    • You will need to move aside the plastic covering that is above each screw.
  7. Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 7 中的图像 1,2 Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, lift the black electrical tape to the left of the touchpad.
    • Remove the black wire running across the touchpad from the two hooks on top of the part.
    • Be careful not to damage the black wire when removing from the two hooks.
  8. Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 8 中的图像 1,2 Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 8 中的图像 2,2
    • Lift the flap on the wire connecting the motherboard and remove the connector.
  9. Acer Chromebook C740-C4PE Touchpad Replacement: 步骤 9 中的图像 1,1
    • Remove the touchpad from the device.
结论
Jacob Kahn
于10/17/17注册
273 声望
创作了2篇指南
团队
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 的会员
UMASSD-ROCKETT-F17S6G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 314
